Re: Replacement lights
Posted by Janicholson on June 22, 2009 at 20:44:47 from (66.173.50.19):
In Reply to: Replacement lights posted by bkpigs on June 22, 2009 at 11:38:20:
Yes but. The original switch uses a resistor (gets hot) to make dim lights. It is direct to the lights on B (bright) This switch cannot handle brighter lights. It can be used to turn on a relay to make brighter sealed beams work, but it is easier to use a different 30 amp switch, and heavier wires. The original sealed beam light bulbs in the pancake housings will take a variety of brighter bulbs, but the switch limits the brightness to standard wattage. To wire a relay, put the power lead to the load side of the amp gauge, and the output (load terminal of the relay) to the light circuit. A relay ground is needed, and a wire from the light switch bright terminal to the relay coil. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
