Take pedal return springs off of pedals. There is a bolt through a heavy spring that enters the brake assembly. I forget if it takes a 9/16 or a 5/8 wrench--remove the bolt keeping the spring & bolt in order. Forgot--there should be a jam-nut on the threaded bolt--loosen it to remove bolt. Should be 5 bolts around circumference of brake housing--remove these. Pull straight out on the brake assembly to remove it. Lay the assembly out on a cardboard & make a mental note of how the discs And actuating plates are arranged in the housing. Check actuating plate return springs[should be 3 of them]. If there are only 1 or 2 springs, you will probably find the remains of them somewhere in the brake casing. As long as you have the brakes out, clean everything up before replacement. Check in with what you find.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
