Re: Farmall 560 hydraulic fuid
Posted by Armand Tatro on June 26, 2009 at 02:38:12 from (71.239.10.80):
In Reply to: Farmall 560 hydraulic fuid posted by James Schroeder on June 25, 2009 at 19:03:55:
The main hyd, pump and the power steering pump are piggy-back togather and share the same filter and oil intake from the transmission. on the left side of the tractor ahead of the clutch and the trans. check plug you see a big steel line that becomes a rubber hose that goes to the bottom of the steeering console and two smaller steel lines that follow the left frame forward to the steering gear pump. The pumps are in the housing where these lines orignate. The trans. holds about 15 gals. of hy-tran but the hyd. pump only uses the top 5 gal(+/-) so when the hyd. pump is low on oil you should have about 10 gal. left in the trans./rearend. Hope this information helps. Armand
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
