Posted by Janicholson on June 26, 2009 at 19:33:07 from (66.173.50.64):
In Reply to: Ih 350 Hi Utility posted by joe/pa on June 26, 2009 at 19:16:07:
They are a nice low production tractor. The battery should be put in positive ground. If it his negative, I would turn it around. Then, before starting it, I would polarize the generator. First connect a jumper between a good ground and the F terminal on the Generator. (this allows the field to get full polarizing current) The next step is at the voltage regulator by using a piece of solid #12 wire to jump between the Bat terminal, and the Arm (or Gen) terminal. Touch it for only one second. It will spark, but that is normal, it will not shock you. Now remove the Field ground, and start it. It should charge (needle to Plus) and it should be good to go. Charging voltage (on a charged up good battery should be between 14.2 and 14.5 volts, when running at 3/4 throttle or more. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
