Posted by puller1 on June 27, 2009 at 12:55:04 from (71.171.1.74):
In Reply to: IH 350 wheel bearing posted by Bob 02 Martin on June 27, 2009 at 12:36:37:
the outside bearing would most easily be removed by sliding out the pto & removing the large bolt at the bull gear. You can press out the axle by backing out the bolt against a block up against the opposite axle.You must first remove the 4 bolts on the cap holding the outside bearing in.The bearing will slide off the axle easier if you will use a wire brush on a grinder to remove any paint & rust from the axle.All this can be done without removing the tranny cover.Murphys law states that if you don't drain the gear oil you will drop the bolt that holds the bull gear & you will drop your wrench several times in it.It is not as bad a job as one would think. Hope this helps. Tim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
