Re: ih 674 hyd problem
Posted by Harold hubbard on June 28, 2009 at 06:07:41 from (205.209.16.24):
In Reply to: ih 674 hyd problem posted by joe 1971 on June 27, 2009 at 15:51:11:
Hydraulic problems, and the brakes don't work right. This is kind of a red flag on any tractor with internal wet brakes. I have been through this movie more than once. The brakes wear out, the disks/bands, disintegrate and the resulting debris clogs the pump intake screen and filters, partially or completely, giving a range of symptoms, from erratic operation to total hydraulic failure. Cleaning the intake screen is a good beginning, if it is badly plugged, you need find out why. Brake failure will show bigger pieces than simple thirty year crud build-up, water contamination will be look like a milkshake, and may take more than one fluid change to clear.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
