Posted by Janicholson on June 28, 2009 at 20:42:02 from (66.173.50.67):
In Reply to: Re: Losing spark. posted by djone110 on June 28, 2009 at 15:48:11:
Almost every one on this board believes that the clear plastic filters are too restrictive on a gravity feed system. NAPA makes a filter for gravity feed. it is not as small. The restriction of a plastic filter seems at first to be irrelevant, but a fuel pump equipped vehicle has 4 to 8psi applied, whereas the gravity feed has only a 15 inch head of pressure. The small plastic filters also have a tough time with flow when even a little plugged up. I would either toss it, or use a gravity flow unit. Bad coils can come from the factory. A true 12v (no external resistor required) coil used with a resistor will not give good spark, (it thinks it is getting 4 volts or so.) also check the side play in the distributor shaft. If you can see or feel play it is too much. JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
