Re: 350 Clutch
Posted by pete 23 on June 29, 2009 at 10:56:43 from (173.87.14.132):
In Reply to: 350 Clutch posted by jerry ray on June 29, 2009 at 06:47:22:
About .380 to .395 seems to ring a bell with me, I may look it up later when I go out to the truck. If the fingers on pressure plate are not laying near parallel with backing plate, disc is worn out or flywheel step is not correct. (not likely). What does happen way too often is the rebuilders of the pressure plates take too much material off pressure plate and destroy integrity of the pressure plate. I have returned some that when you bolted them up to flywheel you had so little tension it wasn't worth putting on. You can have machine shop change dimension of flywheel step to accomodate this but should not have to do that. We normally used new pressure plates (rebuilt our own actally) at the shop but I don't have that option anymore.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
