I'm kinda with Jeff. If you have an experienced radiator shop around, they'll have seen a lot of punctures the size of yours and likely be able to close it right up. If you've got experience in that kind of soldering, there's no reason you couldn't do it yourself. A lot of the trick on radiators (or my take on it anyway) is to focus a lot of heat quickly in a small area so that you're not loosening up some solder somewhere else, like the joint between the upper or lower tank and the core.
Another plus to having the shop do it is that they should pressure test afterwards and fix any pinhole that might be left.
As far as Stop-Leak or something like it, can't hurt might help as long as you have a pressurized system with a pump -- the stuff that does the work needs to stay suspended and it takes pressure from a hot/warm run to force the little flakes into the pinholes. In the non-pressurized thermosiphon systems on the smaller tractors, about all it does is settle and either plug the drain or make a layer of sediment in the bottom, reducing your cooling efficiency. If there's no leak, I wouldn't use it. If there is I'd try to fix it right before using the stuff.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
