Is your magneto still functioning as a magneto or has it had an external coil hung on it? If it is still functioning as a magneto with the internal coil, that primary wire out of the coil has to be connected to the condenser or it will not produce any spark.
If it was converted with an external coil and uses battery power, then the internal coil should be disconnected and the ballast resistor comments are back in play.
If you clean the points with sandpaper, you might as well go ahead and replace them. If they weren't junk before, they will be after. Only use a point file on them.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
