Posted by Owen Aaland on July 03, 2009 at 07:32:53 from (65.165.246.156):
In Reply to: 1066 Problem posted by craig Reavley on July 03, 2009 at 06:44:08:
The only thing the PTO shares with the hydraulics is the common reservoir. The PTO has it's own hydraulic pump and intake filter/screen.
If the PTO has slipped you are going to have to do a total rebuild, not just a clutch pack replacement. Once it slips it ruins the piston seal with the heat generated. The brake pistons are probably worn out also.
It is not a really difficult job but it does take a few tools that most people will not have. Once you remove it from the rear frame you will need some way to compress the springs to remove the snap rings. It also takes a rather special hydraulic fitting to adapt a pressure gauge to the test port to set the hydraulic pressure after the job is done.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
