The bull gear can be lifted from the bottom inside teeth with a flat bar, and shimmed up with bolts Maybe 4" long 1/2" bolts to use as wedges under the gear teeth and against the case. These shims allow adjustment so that the gear is aligned with the splines on the axle, and not canted. Make sure you look at the parts diagram, and deal with the placement of the gear in and out on the axle, as in the repair manual. The differential pinion and ring gear are critical to low noise, and strength. I do not remember the backlash setting, so look it up. The pinion depth and backlash combine to make a good tooth pattern on the ring gear teeth. The whole tooth should have a uniform pressure wipe across its length when it is correct. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
