Re: Char-Lynn hydraulic valve
Posted by Armand Tatro on July 05, 2009 at 07:12:22 from (71.239.10.80):
In Reply to: Char-Lynn hydraulic valve posted by Terry Bahler on July 04, 2009 at 14:03:34:
Your system is plumbed as I thought. I see what appears to be a coupling in at one of the lines to and from the pump by the engine oil frlter. If the pressure line has a coupling there that would be a good place to plumb the Char-lyn valve. Thanks for the pictures. By the way if you can't splice in at the coupling by the oil filter you will have to disconnect the pressure where it enters the hyd. tank and then add another hose from the valve output to the inlet of the hyd. tank Armand
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
