With thinwall sleeves 3-7/16 bore is the most you can go on a regular H block without machine work. If you want to run sleeves the next step with machine work is 3-9/16 bore thinwall SH sleeve and piston set. The block doesn't have to be bored as much with that set compared to the 300, 350 thinwall 3-5/8 ID sleeves. If you run the pistons on the block without sleeves, sometimes some 3-9/16 pistons can be fitted, or the block can be sized for 3-5/8 pistons. If you have a good block casting most all the above will work. If not get ready for more machine work or finding another block. If your tractor is a early one I would pass on boreing it. If you get 3-5/8 pistons, most if not all now have the small piston pin. You would need adapter bushings in your connecting rods to use. some 3-9/16 have the small pin also. Just my opinion when using 3-5/8 pistons and the block bore castings look good. I go for opening the bore roughly 1/16 and running on yhe block. If you wear that out it can be bored for the sleeve then. Know a few that farmed running pistons in block and they lasted good.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
