Posted by spiffy1 on July 08, 2009 at 19:52:59 from (70.41.135.42):
Probably been beat to death here, but my searches didn't quite yield definitve results.
That 22-36 [combination manifold] I fixed up for the neighbor last spring is going on a "power eater" fan or water-break [not positive which, but supposedly set for continuous duty] next week for break-in as the weather has just been too sporatic for putting 3-16s in the dirt.
We thought this would be a perfect time to test out the water jets too as the break would confirm power loss if I miss the audible signs I hope to adjust it with.
However, I know modern kersosene is heavily stripped for clean burning in camp lantern and space heater use, so what should I mix? I'm wavering between #1 diesel with maybe 20% gas and jet fuel [if I can procure it] also cut with maybe 20% gas. If it's real dry; maybe a couple oz of 2-cyle oil to the mix.
Ideally the mix will ping enough force the use of the water carb under load to bring it back to a slight ping. Maybe 50 octane?
What say's the experts?
Also, I suspect this will yield slightly less HP, but slightly [maybe neither one even noticable] better fuel/hphr than gas; but really don't know.
On the positive, this will seldom be ran, as I recommended the oil should be changed and the tractor ran a bit on gas before winter storage if running low-grade-fuel, but it sure would be fun to replicate the original sound and smell of a McCormick Deering on tractor fuel. Can't let the Rumley guys have all the fun! :lol:
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
