Posted by couv on July 09, 2009 at 05:00:56 from (209.33.29.136):
In Reply to: 240 questions posted by Vally Farm on July 08, 2009 at 15:16:16:
Our 1st tractor when we moved back to the Country was a 240, so consequently, all the 2points were cut to the smaller height.
When Dad later traded up to a 424, it had the larger, taller points. There was a pair of shims about 1/2 inch thick, as long as the entire pocket a point slides into to take up the slack. The rear, outer end of the shim was drilled and had a long roll pin in the hole to keep the shim from sliding too far int the pocket and being lost through vibration during use. Each point, therefore, had a short finger below the point, so that it would hold the shims into place from behind.
Same system should work if you have 2 fast hitch tractors, one large, one small. It would be a tough decision to let someone cut all of the points down, and having to use the shims on the larger tractor from that point forward.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
