The epoxy diode will do it. Make sure it conducts toward the alternator, and not the other way. When the alternator is not turning, and the key is on, the #1 terminal appears to be a ground to the system. it is looking for 12 volts to excite (start) the charging. Once it starts charging, the #1 terminal puts out charging volts. This is what needs to be stopped. The diode needs to be at the alternator, in the line to #1 terminal only. If it is between the switch and the coil, it will not work. (put it 2 or three inches from the alternator, and put shrink tubing over it to keep it clean and dry. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
