The correct way is to (I realize the issue) buy a sleeve designed for the hole tolerance. Some have used Iodine as a paint to literally rust the sleeve into the bore. If I were to make do, that is what I would do. It would be very rough on the next rebuild. Doing nothing will not be a good idea. The heat transfer is poor and the sleeve can crack at the top and be pulled down into the rods. Way uncool. If you send your sleeve to LA Sleeve, they will make a new one larger. Tell them the actual bore of the hole. IH made them in select fit sizes. Marked with letters on the block deck. near the cylinder. ABCD D was the largest. Kits tend to use only B size sleeves, but if one went in tough, that sleeve might do wonders in the big hole. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
