Re: How did they lock out 5th gear in the steel wheel tra...
Posted by steve il on July 15, 2009 at 19:46:53 from (99.196.174.11):
In Reply to: How did they lock out 5th gear in the steel wheel tractors? posted by bkpigs on July 15, 2009 at 17:05:18:
usetabesteve said: (quoted from post at 03:31:02 07/16/09) Your two problems might be related. That sloppy shifter might not be pushing the rod far enough to engage fifth gear. Fifth gear is actually a misnomer since fifth is direct drive and the shafts are coupled.
i think theres a type of pilot bearing where the two shafts couple together for 5th gear. i know if it is bad 5th will only grind or it will jump out of gear.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
