The bypass wire causes the tests to be invalid due to the voltage coming to the fault from both sides. One other thing, if the bypass allowed the system to work some, and charge some, and discharge some, the fault may not actually show up as it could if the fault had not been stressed by the current going through it. I would definitely remove and clean each connection, then use a bit of silicone grease to reassemble the clean connections. But clean is a must. The jumper wire is like bypass surgery. Not as good as unclogged arteries, and might give a false sense of wellness. It (in this case) is possible to repair the original arteries. The worst case is that the bypass bypasses the amp gauge, and could result in runaway voltage from the alternator melting and burning the alternator and wiring as well. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
