Re: Farmall F-20 Carb Passage Plugs
Posted by clean John on July 17, 2009 at 18:19:00 from (216.228.193.194):
In Reply to: Farmall F-20 Carb Passage Plugs posted by Andy Motteberg on July 17, 2009 at 17:27:40:
Andy-- I will give you my way of removing these plugs- If they are over 3/16 " get a 3/32 drill bit --grind it on a wheel in reverse of what you see.Center punch the plug as near center as possible- Chuck the bit in a reversable drill . Go slow and make sure you stay in the center--You may want to start with a 16 pilot hole then use the reverse bit.Unless the plug is very tight the revese bit will screw it out --if not drill it to max then use a sqaure e-z out . Hope this helps .Others may use different methods. John
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
