The lifters are down below in the cover behind the distributor. The things up top are rocker arms, push rods, and valves. (springs on valve stems are visible) The Fuel is an unknown, Unless there is a bunch of fuel in the oil from leaving the tank valve on all the time, there should not be fuel there. Antifreeze can be from a head gasket, a cracked cylinder, cracked head, or a bad core plug (Freeze plug is the wrong name). Putting about 7 PSI (MAX) in the radiator will show you the leak. You may need to take off the oil pan to find it, if it is not in the top end. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
