Re: 460 Hydraulics AGAIN !
Posted by Unreserved dick on July 18, 2009 at 08:13:05 from (4.227.251.189):
In Reply to: 460 Hydraulics AGAIN ! posted by Higgi1951 on July 17, 2009 at 07:36:31:
The orifice in your safety/pressure-control valve block is plugged. Your system is consequently continuously loaded and putting that load on the tractor engine. When you move one of the control valve handles you give the hydraulic fluid somewhere to go (to the cylinder controlled by that valve), rather than forcing it to go through the high-pressure safety valve.
This is a pretty common problem for these systems. You'll need to pull the valve block and clean it, especially the orifice in the control circuit. This problem may mean your entire hydraulic system needs to be cleaned out, also.
Good luck.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
