It is not the lease bit unusual for transmission oil to leak out when the PTO splines fail. There is a seal inside that gear which has the splines worn off. As it slips in the pressure plate it is wiggled around the oil will come past the seal.
You will need to resurface the flywheel when you replace the clutch. Once the flywheel is off you can see if the rear crankshaft seal is leaking.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
