Re: TV AND ANY OTHERS
Posted by mkirsch on July 20, 2009 at 05:33:07 from (64.80.108.57):
In Reply to: TV AND ANY OTHERS posted by El Toro on July 20, 2009 at 05:15:08:
El Toro said: (quoted from post at 05:15:08 07/20/09) See if it has a ballast resistor could be defective. Hal
If the ballast resistor were defective, it would NOT run when you released the key. It would only run while you held the key.
On that 4010, I would guess that there is a wire that runs from a post on the solenoid straight to the ignition coil. Like someone else said, this is a "booster" to provide 12V to the coil to get a hotter spark at start time.
Normally power runs through a ballast resistor which provides 6V to the coil. You can't run 12V to the coil all the time or it will burn out.
I would suspect that there is a problem with this wire, or with the solenoid.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
