The mags have no speed related advance mechanism. The impulse coupling is set to trip at TDC. When it starts and gets past the point where the impulse clicks, it goes to full advance. It does not like that at low speeds and idle. I would bet it would run much smoother if the timing was retarded to about 10 or so degrees at idle, but it is at full advance. It will over heat and make no power retarded this much, so it is not an option. Assuming the carb has been tweaked to best running, the only solution is to use a distributor with centrifugal advance. I would put a distributor on it when using it, and a mag when showing. Remember a mag is grounded to stop, and a distributor is shut off from the ignition voltage. If it is crank start only, it may not have a battery. Thus live with it. JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
