Sounds good to me. I've already removed the long bull plug. My recollection is that the drain tube in the rear may allow oil to run right on top of the rear end gear but I'd have to go look again. Since my 2606 doesn't do any heavy long term field work, I probably can't hurt the rear end.
I didn't see a way to unbolt that plate with the drain tube unless the rear end housing was opened up or I believe the draft control housing is removable from the top of the rear end but more of a job than it is worth. If I felt the necessity, I would cut the tube. I did have about an inch worth of sludge I cleaned out of the bottom though. My drain tube had a bead that made it look like it was welded and no thread on it that you would see since tapered pipe thread usually doesn't screw all the way into a nipple. I'm not sure why they would change that particular part with some welded and some threaded though. I just know I put a pipe wrench on it and all I could do was start bending the tube.
On the 2606, my recollection on tracing out the oil cooler line is that it comes back to a block on the side of the draft control housing. I don't see it going to the rear end housing. However the draft control housing itself has some internal passageways in the housing and maybe one of them run down to the rear end and spray oil.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
