If you changed the pump position that much most likely the pump is out of time.
With the engine not running the the rear timing mark should be about the middle of the access opening in the pump housing. Roll the engine over by hand in the direction it normally runs, clockwise, and stop at three degrees BTDC. At that point the two marks should line up. If you do not see the front mark turn the engine one complete turn and recheck. After you make a timing adjustment turn the engine two complete turns to verify that it is correct. Only turn the engine clockwise to check the timing. If you turn it counterclockwise the marks will not line up the same due to play in the gears and pump drive.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
