Just keep in mind that an extended hyd cylinder with plugged ports/hoses and a load on the rod is at static equilibrium...but the fluid pressures are not in equilibrium!
The mechanical force/load on the extended rod is creating a pressure differential across the piston seal. Higher pressure on the bottom of the piston and lower pressure on the rod side of the piston. It is an easy thing to visualize with pressure gages.
If the piston seal cannot maintain the pressure differential (IOW leakage) then the pressures will slowly equalize by virtue of the rod being forced completely into the cylinder and the piston resting on the bottom of the tube (or at any other mechanical travel limiter).
IMHO what you have described is an excellent test to isolate the spool from the piston seal.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
