To remove the pilot bushing I use a slide hammer with the singer finger that screws right onto the shaft. If that's not available, I get a hack saw blade and saw it out.
If the clutch disc were in backwards it would have wobbled on the flywheel when you installed it. The "tall" end of the hub goes away from the flywheel.
To measure the finger height the service manual tells you to measure 2-7/32" from the friction face of the pressure plate to the release bearing contacting surface of the fingers. I did some measuring and reworked a more likely way to adjust it. Measure from the center hub of the clutch disc to the release bearing contacting surface of the fingers and make it 1-21/32". You can adjust the height with the screws and lock nuts on the pressure plate where the fingers attach to it.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
