That would be a starter solenoid. Basically, when you push whatever you have for a starter button, it triggers a relay within the solenoid body to allow current to flow to the starter. Not sure where yours came from, but the wiring concept is the same as what was used on Hs and Ms.
Originally, your starter would have been actuated by a rod, similar looking to your choke rod, which, when pulled, would pull a cam down and depress the starter switch, which was a button mounted on top of the starter. What looks like the hot wire from your battery and the smaller wire probably back to your ammeter on the left-most stud in the picture would have been mounted to the top of the switch body, with the very simple, normally-open switch closed by pulling the rod making the necessary contact for turning instead of the solenoid. Could be any number of reasons it was replaced with a solenoid -- failure of the original switch, wanting the convenience of a push button at the seat instead of the pull-rod . . . who knows?
You can't rule out the solenoid being the source of your short, but if your starter is behaving normally, I'd look elsewhere first.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
