Re: Super C Electrical Question
Posted by John T on July 26, 2009 at 08:53:25 from (66.244.97.31):
In Reply to: Super C Electrical Question posted by JS Kidd on July 26, 2009 at 07:30:59:
I agree with Scotty, thats basically a Ford type of magnetic starter solenoid switch used to replace maybe a push to start original mechanical starter switch. It grounds via its metal mount to the tractors frame
The big cable on the big left post runs down from the batterys + terminal...
The small wire on same terminal likely wires up to the Supply (NOT load side to alternators output) side of an ammeter
The small wire on the lil S terminal wires tp some sort of ignition/start switch that sends hot voltage down to the lil S terminal to engage the starter when you turn it to start or else push some sort of Start button.
The big post on the right has a big cabe to the starter.
QUESTION You mentionEd Ballast Resistor, do you mean it has an in line series ignition ballast resistor wired after the ignition swtich before and ahead of the coil ?? If so its to drop the 12 battery volts down to 6 for a 6 volt coil.....
IFFFFFFF thats indeed what you have I would run a 14 or so gauge wire from that solenoids lil unused I terminal to the high input (from switch NOT to coil) (should be + for Neg ground) coil terminal and that will give you a hotter starting spark. Thats what that extra I solenoid terminal is for
John T
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
