Bob, I think you misread the post. The starter only works with the clutch released. Not pushed down.
Brownie, I loosened the starter bolts then pushed the clutch in and the started moved quite a bit. I think you are on the right track. I am going to check all the affected bolts. Maybe when I push the clutch in the starter is binding on the flywheel or maybe even the throw out bearing is worn (but it is not noisy) Whatever the reason, pushing the clutch in is causing the starter to hang.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
