The crank endplay can make the difference. I would put a clutch type starter drive in it to make it work with the end play. To check endplay, put a dial indicator on the edge of the front pulley. Set it to be aligned with the crank center line. (front to back on rim of pulley) Now push forward on the pulley with a flat bar, then rearward with against the hand crank stub. read the total difference. Normally it is about .004 to .006" if more like .020" it is worn and probably could use a new thrust bearing (main bearing) on the crank. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
