If it has power steering one way but not the other it is not the pump or relief vave. I would check the splined knuckle on the front end of the steering shaft. Those splines cannot be froze to the steering valve input shaft. That input shaft has to move laterally in or out as you turn the wheel left or right. That input shaft moves the control spool inside the control valve. If that knuckle is froze to the input shaft and the u-joint at the suport bracket mounted to the starter is not adjusted correctly the snap ring on the upper end of the steering shaft will limit the lateral movement of the steering spool and cause the problem you are experiencing. Chuck
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
