Posted by Crazy Red Power in SE-WI on July 29, 2009 at 10:37:55 from (24.183.138.183):
called the alternator, was only kinda doing it's job. Seems the alt might not have been spinning fast enough until almost wide open. For reasons unknown, the vr in the alt would continue to do it's thing until I reduced the engine speed, all the way & I have the engine turned down just to where it still idles smooth. Figured this out at about 8 this morning, down at the IH dealer. Bench tested it on a different tester (ancient, yet, expensive looking thing with lotsa neat gauges & lights & switches) that apparently put enough load on something to make it produce majic smoke. "Well, that don't happen often", sayeth the service man. To make a lengthy story a bit short, I opted to purchace a reman alt that charges at lower RPM's, installed it on my tractor & the rotten thing charges. Yay. My next miracle surgury will be removing a filter, in line, between the sediment bowl & strainer screen in the carb. That & the removal of a yellow filler neck from a gas can that's floating around in the gas tank. To JimN, Thresherman & the rest of you, I thank you kindly for your help & patience with my "dumb donkey" ;^). In the mean time, I'm off to catch a nap. Didn't sleep much last night & was up at 5. - Mike
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
