Re: SH Voltage Regulator Update
Posted by JMOR on July 29, 2009 at 16:27:02 from (72.181.158.237):
In Reply to: SH Voltage Regulator Update posted by wm on July 29, 2009 at 10:44:23:
GordoSD said: (quoted from post at 18:37:25 07/29/09) Could I just remove the VR cover and see what the points are doing? Close them both "manually" using maybe popsicle stick,and observe the ammeter?
Gordo
Absolutely!
When gen starts to output a significant voltage ( above batt voltage) the cut out contacts should close.
When battery voltage is very low, the field contacts stay closed (for max output) & as battery charges up (voltage goes up) & field contacts begin to switch on & off at a rapid rate (like a vibration) and if battery is absolutely fully charged, the field contacts will remain open most of the time,( for minimum charge).
Bob's analysis would yield situation where field contacts are open all the time (hope not putting incorrect words in Bob's mouth).
And when engine is at a very slow idle or stalled, the cut out contacts open, disconnecting gen from battery.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
