Posted by J.J. from Afton on July 30, 2009 at 10:31:29 from (207.118.130.165):
In Reply to: axle swap posted by DK44H on July 29, 2009 at 20:27:21:
Its not too hard. Helps to have two people to handle the tire and wheel and axle. Usually you can undo the bullgear from the rear axle by removing the PTO and reaching into the transmission through that opening rather than removing the transmission cover. To start remove the wheel and center off the axle, than take off the square cover on the housing holding the seal and bearing. Than just remove the bolt and washer holding the bullgear, it helps to use shims to prop the gear up so it doesnt fall. and than you can pull the axle right out of the housing. To reassemble just reverse the process.
The picture shown is of a 560W axle but the procedure is still the same.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
