If you have the rigid steel lines, like my 400, the smaller diameter line is the pressure line. The larger line is the supply line. To prime mine, I took the set screw off the pump that is over the relief valve and kept adding HY-TRAN until if would not take anymore. It will drain down a few times before the lines are full. Just be sure that the setscrew does not get cross threaded, because it does not sit in the housing straight or flat. I wrecked one that way. Steve
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
