We really need to know what the charging voltage is. There might be nothing wrong with the system at other than an ammeter that is a bit more sensitive than most, as indicated by the amount of discharge with just the switch turned on.
The battery gets drawn down when the starter is used and will except a high charge rate for a period of time as it recharges. The amperage should drop down as the battery reaches full charge. As long as the charging voltage is no more than eight volts at the battery you should be alright. Closer to seven volts would be better.
A fully charged six volt battery should have 6.3 volts. 6.5 volts will charge the battery but it will take a long time. A tractor that is used regularly for more than short periods at a time will be OK with a charging system that maintains 7 volts. Much more than that and you will have to keep adding water to the battery. Tractors that get run less frequently and for short periods at a time will do better with a higher charging rate. The higher the voltage the quicker the battery will recharge. The higher the voltage maintained while charging, the more likely you are to boil out the water.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
