Well the pump on the Liftall does not work at all unless the rod is pulled. The hitch is set up as lift and down force (double acting) and is correct as is. The rod on the Liftall can be wired back, leaving it on all the time. It hurts nothing to do so. The cap can be sealed with no opening at all (the two way cylinder gives back very close to what it puts out, so no vent is needed (I recommend this as it keeps moisture and dirt out) the dipstick is extended because the setup for the return line T raised the dipstick location. It seems a bit cobbled, but might not come out if it was a solid 1/8" rod that was stock. The stock stick is on a washer just as yours is. The diagram shows the return in the bottom of the Liftall drain. This is a bit less messy, and works well. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
