Valve setting I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal The cold setting is .020" all valves. Take out the plugs. (turn it with a wrench, on the front nut) Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the intake when the exhaust just closes. This is the two positions that can be seen on each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE) Look at #1 valves, Turn the engine till the intake just starts to begin opening (moves) then adjust the exhaust valve. Rotate more until the exhaust just closes (just stops moving after having been open) and adjust the intake. Treat every cylinder (pair of valves shown above the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Second setting warmed up, not hot, is .017" JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
