Posted by mattofvinings on August 03, 2009 at 14:43:51 from (67.142.161.29):
In Reply to: Head bolts posted by Bill in IL on August 03, 2009 at 12:54:33:
I have used Grade B7 threaded rod to make head studs before. This steel very closely approximates a Grade 5 bolt. I ordered it from McMaster-Carr
The studs are still running in a Continental flathead engine in one of my forklifts. The way I use it is not quite the duty cycle of a tractor but I don't see a good engineering reason why it should not work. The torque specs will probably have to be adjusted if the stud is all coarse thread and the original setup used a fine thread.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
