What sort of a puller are you using? (pics would be nice) And have you verified that you have clearance to the flange at the top of the sleeve so you are actually pulling relative to the block and not simply attempting to crush the sleeve?
Relative to the Sawzall, that's a classic method for removing a generic sleeve but I'd be worried about going too deep. I think I'd try a file or a die grinder first to create a couple notches which might create a (helpful) fracture.
IMHO while there are a few torch wizards out there that's a little too sensitive for the typical class of work. Any burrs, bubbles, or drips will create resistance and be dragged past the existing machining, creating damage.
Here is what I used on my 340's engine block recently. This worked well. The bottom puck has a pilot which clears the sleeve bore by about .020". It simply keeps the threaded rod centered. and the OD is slightly undersized as well so it doesn't drag any more than the OD of the sleeve.
This post was edited by mattofvinings at 15:30:30 08/03/09 2 times.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
