To be perfect, drain all the fluid out, and put in 6 qts. Mark the stick. I think the stick is 8" long and is marked at about 7 inches for full. The system does not care much unless low enough to starve the pump. The rod should be 1/8" steel with the top going through a fabricated washer with a 1/8" hole in it that fits inside the cap, and onto the top of the stand pipe. The washer is held on, on the factory stick, with a deformed spot above and below the stick. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
