When you tried to prime the pump, how much were you able to put in? The fluid needs to drain down into the supply line and it may take awhile for that to happen. Be patient and keep filling it until you are sure that it will not take any more. The pump will most likely only pull as much oil, as it has in the pump and that may not be enough to get the fluid to draw out of the reservoir.
There is a plug on the side of the safety/regulator valve that you may want to try and loosen to bleed air out of the system if you think the pump has fluid to it. Good Luck Steve
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
