1 - Yes! A properly wired ammeter deflecting to the right of 0 indicates the battery is being charged. The greater the deflection the higher the charge rate.
2 - It depends. If you are starting/running the tractor for only short periods (5 - 10 minutes), or running mostly at low RPMs, set the switch to "high" to keep the battery up.
However if you're running at governed RPM for extended periods set the switch to "low". Otherwise you'll overcharge the battery and shorten its life. (A nearly new battery exploded on my Minnie-Mo last winter when the operator (not me!) inadvertantly knocked the charge switch to "high" then ran the tractor at speed for a couple hours.)
Tip: Unless you are a stickler for originality, a better approach is to replace the cutout with a voltage regulator and dispense with the manual charge control.
A VR does a MUCH better job maintaining a proper charge rate. This keeps the battery more fully charged and eliminates the risk of overcharging.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
