gmd said: (quoted from post at 18:25:15 08/06/09) on my fathers 340 the ta just stopped working one day when he was using it. It is stuck in the low side. he said it didn't make any noise- no grinding/banging/broken mechanical indication. Knowing very little about the innards of a ta, is there a way to tell without tearing everything apart whether or not its an adjustment issue?
Thanks!
Unless the TA clutch lever is stuck in the released position the failure is in the TA clutch. If it still has the original disk with woven linings the most likely problem is the lining coming off the disk. The rivets can come loose and the lining fall off or more likely letting the tractor coast down hill in the low TA position. That over speeds the disk can cause the lining to come off even if the rivets are tight. Replacement disks are bonded metalic lining that handles the speed much better.
The clutch can be inspected by removing the cover on top of the clutch housing, the stamped steel one held on by four bolts. The TA clutch can be replaced by splitting the tractor at the engine clutch.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
