Posted by Matt_In_Michigan on August 07, 2009 at 21:02:31 from (208.53.98.232):
In Reply to: 560G Hydraulics posted by Matt_In_Michigan on August 07, 2009 at 14:20:11:
I think I found my solution. The lousy hydraulic pump needs to be replaced, but its not related to the tranny. Found this GEM hunting through the archives. Thanks to Captaink!
"Your 560 is very likely suffering from the common Red Iron ailment of a worn shift lever. To make sure, take out the three cap screws at the bottom of the shifter tower and lift the shifter out. What you will see are three shift rails, (approx 3/8 wide) and two dividers (approx 1/16 inch wide) with about a 5/8 slot in them. To have the transmission in neutral, all the slots must line up. With the shifter or a large screwdriver or other pry bar move the rails until the notches line up with the dividers. You may need to depress the clutch, pull the TA lever, and rock the tractor back and forth to accomplish this.
After aligning them, you can put the shifter back in (make sure that the bottom of the shifter lever goes into a notch. BUT before you do this, take a good look at the bottom of the shifter and determine how much it is worn. I usually build mine up plenty, then grind them back down until they just barely fit and work, that way it will be a long time until this problem occurs again."
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
