Posted by ScottyHOMEy on August 08, 2009 at 15:36:59 from (70.105.230.139):
In Reply to: Magneto help please posted by Farmall Bob09 on August 08, 2009 at 15:20:18:
There should be a slotted lug on the back of the mag drive gear on the motor that aligns with the lugs on the mag. To get the mag set up on #1, put the cap on briefly and look a the mag right side up (coil cap on top) from the cap end. #1 is customarily at about 2 o'clock. Make a crayon mark on the mag body that lines up with the center of the #1 wire tower.
Pull the cap and put the rotor on. Turn the drive end of the mag by hand, snapping it by the other positions if needs be until the rotor starts to come up on the mark you made. Slow down and you should come to a point that feels almost like a cammed stop, and you'll find a point where the rotor will stay put. If you should snap past that point so that the rotor and drive end are all afloat and will move back and forth, go around again. Stop at each position to help you geta feel for it and set it up to rest at #1. At that point the lugs between the drive on the motor and the end of the mag should be close enough to inline to assemble and get on with the business of timing.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
